Introdução
This guide will most likely be utilized if one of the RAM modules becomes corrupted or you wish to upgrade to a higher amount of RAM if applicable.
O que você precisa
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
Remove the memory stick from the laptop.
Repeat these steps to remove the second memory stick.
9 outras pessoas executaram este guia.
