Introdução
The palm rest is the top cover for the laptop which is responsible for holding the laptop's touch pad. You can use this guide to clean the touch pad or to replace a broken touch pad by purchasing a new palm rest.
O que você precisa
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
Unsecure the wires from the routing guides so they are loose.
5 outras pessoas executaram este guia.
