Introdução
There are many parts that can go bad within a display. This guide does not necessarily cover the replacement of all the smaller pieces, but it does allow you to access those parts.
O que você precisa
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
The connector latch is the black piece.
Good tip! As shown. flips up and toward user
Remove the two screws (5.5mm, Phillips #1) from the laptop base.
10 outras pessoas executaram este guia.
3 comentários
wow that is really good
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
put it back toghther, then plug in a external monitor
Feyrowan -
