Introdução
This guide will be utilized mainly if your CPU has gone bad and your laptop is essentially nonfunctional.
O que você precisa
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
7 outras pessoas executaram este guia.
