Introdução
The Center Control Cover has no real function except for protecting the more complicated components of the laptop. If the laptop is dropped and this component is cracked it may need to be replaced.
O que você precisa
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
