Ir para o conteúdo principal
Dell Inspiron 1545 CPU Heat Sink Replacement
O que você precisa
  1. Dell Inspiron 1545 CPU Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 CPU Heat Sink Replacement: passo 2, imagem 1 %32
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 CPU Heat Sink Replacement: passo 3, imagem 1 %32
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 CPU Heat Sink Replacement, Base Cover: passo 4, imagem 1 %32
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 CPU Heat Sink Replacement: passo 5, imagem 1 %32 Dell Inspiron 1545 CPU Heat Sink Replacement: passo 5, imagem 2 %32
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 CPU Heat Sink Replacement, CPU Heat Sink: passo 6, imagem 1 %32
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 CPU Heat Sink Replacement: passo 7, imagem 1 %32
    • Pull up on the Heat Sink unit to remove it.
Conclusão
6 outras pessoas executaram este guia.
Nathan Lemay
Membro desde: 04/16/14
3.052 Reputação
Autoria de 15 guias
Equipe
Cal Poly, Team 9-14, Regan Spring 2014 Membro de Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 2,022
