Ir para o conteúdo principal
Dell Inspiron 1526 Webcam Replacement
O que você precisa
  1. Dell Inspiron 1526 Webcam Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 1526 Webcam Replacement, Battery: passo 1, imagem 3 %32
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Webcam Replacement, Keyboard: passo 2, imagem 1 %32
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Webcam Replacement: passo 3, imagem 1 %32
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Webcam Replacement: passo 4, imagem 1 %32
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Webcam Replacement: passo 5, imagem 1 %32
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Webcam Replacement: passo 6, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement: passo 6, imagem 2 %32
    • Remove the control cover.
  7. Dell Inspiron 1526 Webcam Replacement: passo 7, imagem 1 %32
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Webcam Replacement: passo 8, imagem 1 %32
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Webcam Replacement: passo 9, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement: passo 9, imagem 2 %32
    • Remove the keyboard.
  10. Dell Inspiron 1526 Webcam Replacement, Screen: passo 10, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement, Screen: passo 10, imagem 2 %32
    • Remove the six plastic pads around the bezel using an iFixit opening pick.
    • Remove the six 3mm Phillips #0 screws under each pad.
  11. Dell Inspiron 1526 Webcam Replacement: passo 11, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement: passo 11, imagem 2 %32 Dell Inspiron 1526 Webcam Replacement: passo 11, imagem 3 %32
    • Open the computer so that it rests flat on the table.
    • Separate the bezel from the black plastic frame using a spudger.
    • There are a dozen snaps around the perimeter of the bezel and there are two between the pivot joints of the laptop.
  12. Dell Inspiron 1526 Webcam Replacement: passo 12, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement: passo 12, imagem 2 %32
    • Remove the two 3mm Phillips #1 screws at the bottom of the display panel.
    • Lift the display slightly from the top, then pull outwards.
    • Flip the display panel around to the back.
    • Disconnect the connector and remove the ribbon cable.
  13. Dell Inspiron 1526 Webcam Replacement, Webcam: passo 13, imagem 1 %32 Dell Inspiron 1526 Webcam Replacement, Webcam: passo 13, imagem 2 %32
    • Detach the webcam connector.
  14. Dell Inspiron 1526 Webcam Replacement: passo 14, imagem 1 %32
    • From both sides, pry and pull upwards from the back of the display cover.
    • This module has no screws affixing it to the display cover; it is held in by snapping it into the plastic brackets.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 136
