Introdução
In this guide, we will be showing you how to remove and replace the Memory Module.
Peças
Não são necessárias peças.
  1. Follow the procedures in Before You Begin. Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
    • Follow the procedures in Before You Begin.
    • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
  2. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips. NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the module from the connector.
    • Remove the module from the connector.
  5. Align the notch in the module edge connector with the tab in the connector slot. Align the notch in the module edge connector with the tab in the connector slot.
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
  7. NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • Replace the memory module cover.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 8
