Ir para o conteúdo principal
Dell Inspiron 1525 Wireless Mini-Card Replacement
O que você precisa
  1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: passo 3, imagem 1 %32 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: passo 4, imagem 1 %32 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: passo 4, imagem 2 %32
    • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
  5. Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 5, imagem 1 %32 Dell Inspiron 1525 Wireless Mini-Card Replacement: passo 5, imagem 2 %32
    • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
    • The card will tilt up when you remove the screw.
    • Slide the card straight out.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 33
Duração total: 8,995
