Ir para o conteúdo principal
Dell Inspiron 1525 RAM Replacement
O que você precisa
  1. Dell Inspiron 1525 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 RAM Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 RAM Replacement, Bottom Cover: passo 3, imagem 1 %32 Dell Inspiron 1525 RAM Replacement, Bottom Cover: passo 3, imagem 2 %32
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 RAM Replacement, RAM: passo 4, imagem 1 %32 Dell Inspiron 1525 RAM Replacement, RAM: passo 4, imagem 2 %32 Dell Inspiron 1525 RAM Replacement, RAM: passo 4, imagem 3 %32
    • Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
    • Carefully remove the RAM chip by pulling it out at a slight vertical angle.
  5. Dell Inspiron 1525 RAM Replacement: passo 5, imagem 1 %32 Dell Inspiron 1525 RAM Replacement: passo 5, imagem 2 %32
    • Remove the lower RAM chip in the same fashion as the upper one.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 24
Duração total: 10,937
