Ir para o conteúdo principal
Dell Inspiron 1525 LCD Replacement
O que você precisa
  1. Dell Inspiron 1525 LCD Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 LCD Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 LCD Replacement, Central Control Cover: passo 3, imagem 1 %32
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 LCD Replacement: passo 4, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 4, imagem 2 %32 Dell Inspiron 1525 LCD Replacement: passo 4, imagem 3 %32
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 LCD Replacement: passo 5, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 5, imagem 2 %32 Dell Inspiron 1525 LCD Replacement: passo 5, imagem 3 %32
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 LCD Replacement, Keyboard: passo 6, imagem 1 %32 Dell Inspiron 1525 LCD Replacement, Keyboard: passo 6, imagem 2 %32
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 LCD Replacement: passo 7, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 7, imagem 2 %32
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  8. Dell Inspiron 1525 LCD Replacement, Bottom Cover: passo 8, imagem 1 %32 Dell Inspiron 1525 LCD Replacement, Bottom Cover: passo 8, imagem 2 %32
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  9. Dell Inspiron 1525 LCD Replacement, Display Assembly: passo 9, imagem 1 %32 Dell Inspiron 1525 LCD Replacement, Display Assembly: passo 9, imagem 2 %32 Dell Inspiron 1525 LCD Replacement, Display Assembly: passo 9, imagem 3 %32
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  10. Dell Inspiron 1525 LCD Replacement: passo 10, imagem 1 %32
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  11. Dell Inspiron 1525 LCD Replacement: passo 11, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 11, imagem 2 %32 Dell Inspiron 1525 LCD Replacement: passo 11, imagem 3 %32
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  12. Dell Inspiron 1525 LCD Replacement: passo 12, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 12, imagem 2 %32
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  13. Dell Inspiron 1525 LCD Replacement: passo 13, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 13, imagem 2 %32
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  14. Dell Inspiron 1525 LCD Replacement: passo 14, imagem 1 %32
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
  15. Dell Inspiron 1525 LCD Replacement, LCD: passo 15, imagem 1 %32 Dell Inspiron 1525 LCD Replacement, LCD: passo 15, imagem 2 %32
    • Use the pointed side of a spudger to peel the six small rubber feet off the display assembly.
    • Remove the six 6.05 mm Phillips #1 screws hidden beneath each of the rubber feet.
    • You may need to scrape glue out of the screw heads for the screwdriver to fit properly.
  16. Dell Inspiron 1525 LCD Replacement: passo 16, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 16, imagem 2 %32 Dell Inspiron 1525 LCD Replacement: passo 16, imagem 3 %32
    • Use the flat end of a spudger to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  17. Dell Inspiron 1525 LCD Replacement: passo 17, imagem 1 %32 Dell Inspiron 1525 LCD Replacement: passo 17, imagem 2 %32
    • Remove the two 5.70 mm Phillips #1 screws securing the LCD to the display assembly.
    • Remove the LCD from the display assembly.
Conclusão
15 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 15,061
