Ir para o conteúdo principal
Dell Inspiron 1525 Hard Drive Tray Replacement
O que você precisa
  1. Dell Inspiron 1525 Hard Drive Tray Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Hard Drive Tray Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 Hard Drive Tray Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, imagem 2 %32 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
    • Slide the hard drive and hard drive tray out of the laptop.
  4. Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: passo 4, imagem 1 %32 Dell Inspiron 1525 Hard Drive Tray Replacement, Hard Drive Tray: passo 4, imagem 2 %32
    • Remove the two 3.55 mm Phillips #1 screws securing the hard drive to the hard drive tray.
    • There is 1 screw on each side of the tray.
    • Remove the hard drive from the tray.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 3,353
