Ir para o conteúdo principal
Dell Inspiron 1525 Central Control Cover Replacement
O que você precisa
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: passo 2, imagem 1 %32 Dell Inspiron 1525 Central Control Cover Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: passo 3, imagem 1 %32
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: passo 4, imagem 1 %32 Dell Inspiron 1525 Central Control Cover Replacement: passo 4, imagem 2 %32 Dell Inspiron 1525 Central Control Cover Replacement: passo 4, imagem 3 %32
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: passo 5, imagem 1 %32 Dell Inspiron 1525 Central Control Cover Replacement: passo 5, imagem 2 %32 Dell Inspiron 1525 Central Control Cover Replacement: passo 5, imagem 3 %32
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 21
Duração total: 3,647
