Introdução
In this guide we will be showing you how to replace the battery on your Dell Inspiron 1525. You don't need any tools for this process.
Flip the computer upside down and locate the battery release switch.
  • Flip the computer upside down and locate the battery release switch.
  • Remember to disconnect any and all power sources when working on any electronic device to prevent damage.
Adicionar comentário
Slide and hold the switch away from the lock symbol to release the battery lock.
  • Slide and hold the switch away from the lock symbol to release the battery lock.
  • Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
Conclusão
3 outras pessoas concluíram este guia.
Phil Hopkins
308 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-101, Johann Spring 2010 Membro de Cal Poly, Team 23-101, Johann Spring 2010
CPSU-JOHANN-S10S23G101
2 Membros
1 Guide authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Todo: 4,577
