Introdução
This guide will show you how to remove a few components of your laptop in order to gain access to the CPU.
O que você precisa
Find the two small indentations of the sides of the panel covering the power button.
Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place.
Remove these two screws with a Phillips #1 screwdriver.
Remove the WLAN panel by pulling it up with your hand.
Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver.
Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
Remove the thirteen indicated screws with a Phillips #1 screwdriver.
Locate the four 4 mm Phillips #1 screws securing the panel underneath the keyboard.
Remove the four screws with a Phillips #1 screwdriver.
Gently lift panel underneath the keyboard with both hands, thus removing it from the laptop.
4 outras pessoas executaram este guia.
