Ir para o conteúdo principal
Dell Inspiron 1520 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1520 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Remove the four M3 x 3-mm screws that secure the hard drive.
  2. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: passo 2, imagem 1 %32
    • Slide the hard drive out of the computer.
  3. Dell Inspiron 1520 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two M3 x 3-mm screws from each side of the hard drive bezel, then pull to separate the bezel from the hard drive.
  4. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: passo 4, imagem 2 %32
    • Slide the hard drive bezel onto the NEW hard drive, then tighten the two M3 x 3-mm screws to secure the bezel to the drive.
    • NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector.
  5. Dell Inspiron 1520 Hard Drive Replacement, Sliding the Hard Drive: passo 5, imagem 1 %32
    • Slide the hard drive into the hard drive bay until the drive is fully seated.
  6. Dell Inspiron 1520 Hard Drive Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the four M3 x 3-mm screws to secure the hard drive.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 854
