Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
O que você precisa
Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
Lift the display cable and antenna cables from beneath the tabs on the palm rest.
Align the display hinges with the holes in the base of the computer, then lower the display into place.
Slide the antenna cables through the hole in the palm rest and the base of the computer.
Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
Connect the display cable to the display cable connector on the system board.
Replace the two M2.5 x 8-mm screws on the bottom of the computer.
Replace the Mini Card compartment cover and tighten the screws.
