Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will teach you how to replace the wireless mini-card in your laptop.
Peças
Nenhum componente especificado.
  1. Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Open the laptop all the way, rotating the display so that it is level with the surface that you are working on. Insert the spudger underneath the groove on the right side of the hinge cover.
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  4. Remove the two 5mm JIS #1 screws from the top of the keyboard. Lift the top of the keyboard up and pull the keyboard away from the laptop. Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
  5. Open the latch holding the ribbon from the top Remove the keyboard from the laptop.
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
  6. Remove the two wires from their connections. Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the two wires from their connections.
    • Pull the metal tabs securing the wireless mini-card to the back of the laptop until the card pops up.
    • Remove the wireless mini-card from the laptop.
Conclusão
Don Dao
Membro desde: 01/03/2018
325 Reputação
4 Guias de autoria
Equipe
I have a computer like this. I have a problem that I have not been able to find a solution too. A few parts that support the screen are broken, and I need to know if I will not be able to replace the CPU in the future should I ever decide to cement these specific parts together.
Let me know if you need any more information!
Peter C.
Peter Chapin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 265
