Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will show you how to remove the memory from your device.
Peças
Nenhum componente especificado.
  1. Place the laptop facedown with the battery facing you. Push the switch above the battery to the right and hold it in that position. Lift the battery using the grip on the top and remove it from its socket.
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
  2. Loosen the two JIS #1 8mm screws on the cover. Lift and remove the cover. Lift and remove the cover.
    • Loosen the two JIS #1 8mm screws on the cover.
    • Lift and remove the cover.
  3. Pull the two metal clips holding down the card apart. Lift and pull out the card.
    • Pull the two metal clips holding down the card apart.
    • Lift and pull out the card.
Conclusão
Ravon Williams
Membro desde: 16/04/2018
169 Reputação
2 Guias de autoria
Equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 241
