Ir para o conteúdo principal
Dell Inspiron 1501 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1501 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Ensure you have the correct screwdriver,( Phillips head #1) to perform the Hard Drive replacement.
  2. Dell Inspiron 1501 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery by pushing back small switch and pulling the battery out of the designated battery area.
  3. Dell Inspiron 1501 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 1501 Hard Drive Replacement: passo 3, imagem 2 %32
    • Unscrew the two phillips #1 screws holding the hard drive in place.
  4. Dell Inspiron 1501 Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the hard drive out slowly
  5. Dell Inspiron 1501 Hard Drive Replacement: passo 5, imagem 1 %32
    • Unscrew both phillips #1 screws holding the hard drive in the frame.
  6. Dell Inspiron 1501 Hard Drive Replacement: passo 6, imagem 1 %32
    • Replace your hard drive with the new hard drive.
  7. Dell Inspiron 1501 Hard Drive Replacement: passo 7, imagem 1 %32
    • Replace the philips #1 screws removed from the hard drive frame securing the new hard drive.
  8. Dell Inspiron 1501 Hard Drive Replacement: passo 8, imagem 1 %32
    • Slide new hard drive back into laptop frame.
  9. Dell Inspiron 1501 Hard Drive Replacement: passo 9, imagem 1 %32
    • Re-screw hard drive back into laptop.
Conclusão
Abraham Mendoza
Membro desde: 01/12/18
176 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 790
