Ir para o conteúdo principal
Dell Inspiron 1501 Display Replacement
O que você precisa
  1. Dell Inspiron 1501 Display Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 1501 Display Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 1501 Display Replacement, Battery: passo 1, imagem 3 %32
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
    Pergunte ao FixBot
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: passo 2, imagem 1 %32 Dell Inspiron 1501 Display Replacement, Hinge Cover: passo 2, imagem 2 %32
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
    Pergunte ao FixBot
  3. Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, imagem 1 %32 Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, imagem 2 %32 Dell Inspiron 1501 Display Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    Pergunte ao FixBot
  4. Dell Inspiron 1501 Display Replacement: passo 4, imagem 1 %32 Dell Inspiron 1501 Display Replacement: passo 4, imagem 2 %32
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
    Pergunte ao FixBot
  5. Dell Inspiron 1501 Display Replacement, Display: passo 5, imagem 1 %32 Dell Inspiron 1501 Display Replacement, Display: passo 5, imagem 2 %32
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
    Pergunte ao FixBot
  6. Dell Inspiron 1501 Display Replacement: passo 6, imagem 1 %32
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
    Pergunte ao FixBot
  7. Dell Inspiron 1501 Display Replacement: passo 7, imagem 1 %32 Dell Inspiron 1501 Display Replacement: passo 7, imagem 2 %32
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
    Pergunte ao FixBot
  8. Dell Inspiron 1501 Display Replacement: passo 8, imagem 1 %32 Dell Inspiron 1501 Display Replacement: passo 8, imagem 2 %32 Dell Inspiron 1501 Display Replacement: passo 8, imagem 3 %32
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
    Pergunte ao FixBot
  9. Dell Inspiron 1501 Display Replacement: passo 9, imagem 1 %32
    • Remove the display from the rest of the device.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 59
Ao todo: 1,272
