Introdução
The following guide will demonstrate how to replace the wireless card in the Dell Inspiron 15-7567. You may need to replace if your wireless connection is bad.
O que você precisa
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
