Ir para o conteúdo principal
Dell Inspiron 15-7567 RAM Replacement
O que você precisa
  1. Dell Inspiron 15-7567 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 RAM Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement: passo 2, imagem 2 %32
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 RAM Replacement: passo 3, imagem 1 %32
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 RAM Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement: passo 4, imagem 2 %32
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 RAM Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 RAM Replacement: passo 6, imagem 1 %32
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 RAM Replacement, RAM: passo 7, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement, RAM: passo 7, imagem 2 %32
    • Remove the 3mm screw on the back using a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 RAM Replacement: passo 8, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement: passo 8, imagem 2 %32
    • Remove the panel by lifting up the side towards you
  9. Dell Inspiron 15-7567 RAM Replacement: passo 9, imagem 1 %32 Dell Inspiron 15-7567 RAM Replacement: passo 9, imagem 2 %32
    • Release the two clips on the left and right side, by pushing outward on the side towards you.
    • The RAM strip will extend out. Pull towards you at a slight angle.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 697
