Ir para o conteúdo principal
Dell Inspiron 15-7559 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-7559 Keyboard Replacement: passo 2, imagem 2 %32
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-7559 Keyboard Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-7559 Keyboard Replacement: passo 3, imagem 3 %32
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: passo 4, imagem 1 %32
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Conclusão
8 outras pessoas executaram este guia.
Equipe
UW Tacoma, Team S3-G2, Liner Fall 2017 Membro de UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
Membros da 5
Autoria de 9 guias
2 comentários
How to put it back
Using Name - Responder
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 33
Duração total: 6,953
