Ir para o conteúdo principal
Dell Inspiron 15-7548 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 15-7548 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Motherboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-7548 Motherboard Replacement: passo 2, imagem 2 %32
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the screws holding the battery.
  4. Dell Inspiron 15-7548 Motherboard Replacement: passo 4, imagem 1 %32
    • Disconnect the battery ribbon connector.
  5. Dell Inspiron 15-7548 Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the CPU fan ribbon.
  6. Dell Inspiron 15-7548 Motherboard Replacement: passo 6, imagem 1 %32
    • Disconnect the display screen ribbon connector.
  7. Dell Inspiron 15-7548 Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the blue ribbon connector.
  8. Dell Inspiron 15-7548 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the blue and gold ribbon connectors.
  9. Dell Inspiron 15-7548 Motherboard Replacement: passo 9, imagem 1 %32
    • Disconnect the speaker cable.
  10. Dell Inspiron 15-7548 Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect the WiFi card connections.
  11. Dell Inspiron 15-7548 Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the screws securing the heat sink.
  12. Dell Inspiron 15-7548 Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the heat sink.
  13. Dell Inspiron 15-7548 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the motherboard screws.
  14. Dell Inspiron 15-7548 Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the motherboard.
Conclusão
Michael Nunez
Membro desde: 04/12/22
325 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Beck Spring 2022 Membro de IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 558
