Introdução
This guide will walk you through how to remove the power port in your Dell Inspiron 15-7548.
O que você precisa
Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
Grab the wires and lightly pull to remove the power port from the motherboard.
Uma outra pessoa concluiu este guia.
