Ir para o conteúdo principal
Dell Inspiron 15-7548 Battery Replacement
O que você precisa
  1. Dell Inspiron 15-7548  Battery Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 15-7548  Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548  Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-7548  Battery Replacement: passo 2, imagem 2 %32
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548  Battery Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 15-7548  Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548  Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7548  Battery Replacement: passo 4, imagem 2 %32
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
Conclusão
4 outras pessoas executaram este guia.
Um comentário
Little grey piece on the cable popped off, will that affect anything? Laptop isn’t recognizing that it has a battery after I took it out and put it back in.
Taylor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 2,498
