Ir para o conteúdo principal
Dell Inspiron 15-7547 Speakers Replacement
O que você precisa
  1. Dell Inspiron 15-7547 Speakers Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Speakers Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Speakers Replacement, Speakers: passo 3, imagem 1 %32 Dell Inspiron 15-7547 Speakers Replacement, Speakers: passo 3, imagem 2 %32 Dell Inspiron 15-7547 Speakers Replacement, Speakers: passo 3, imagem 3 %32
    • Orient the computer so that the hinge for the display facing away from you.
    • Start removing the speaker on the left by pushing the speaker in the direction of the tick mark on the 2 outer pegs, then upwards
    • The tick marks on the two marked pegs should indicate the speaker needs to be pushed towards the center of the front of the chassis.
  4. Dell Inspiron 15-7547 Speakers Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7547 Speakers Replacement: passo 4, imagem 2 %32
    • Remove the left speaker by pushing the speaker in the direction of the tick mark on the center peg, then upwards
    • The tick mark should indicate towards the middle of the back of the chassis.
  5. Dell Inspiron 15-7547 Speakers Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-7547 Speakers Replacement: passo 5, imagem 2 %32
    • Remove the wire connecting the left speaker to the right speaker.
    • The wire is secured by small notches, be careful not to break these.
  6. Dell Inspiron 15-7547 Speakers Replacement: passo 6, imagem 1 %32 Dell Inspiron 15-7547 Speakers Replacement: passo 6, imagem 2 %32
    • Start removing the right speaker by pushing the speaker in the direction of the tick marks on the 2 pegs closest to the front of the device, and then upwards.
    • These tick marks should indicate towards the middle of the back of the chassis.
  7. Dell Inspiron 15-7547 Speakers Replacement: passo 7, imagem 1 %32
    • Remove the right speaker by pushing in the direction of the tick mark on the final peg, and then upwards.
    • This tick mark should point towards the center of the right side of the chassis.
  8. Dell Inspiron 15-7547 Speakers Replacement: passo 8, imagem 1 %32 Dell Inspiron 15-7547 Speakers Replacement: passo 8, imagem 2 %32
    • Remove the cable connecting the right speaker to the motherboard by pulling towards the front of the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 586
