Ir para o conteúdo principal
Dell Inspiron 15-7547 RAM Replacement
O que você precisa
  1. Dell Inspiron 15-7547 RAM Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 RAM Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 RAM Replacement, RAM: passo 3, imagem 1 %32 Dell Inspiron 15-7547 RAM Replacement, RAM: passo 3, imagem 2 %32 Dell Inspiron 15-7547 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Remove the plastic heat spreader that covers the RAM sticks.
  4. Dell Inspiron 15-7547 RAM Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7547 RAM Replacement: passo 4, imagem 2 %32
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  5. Dell Inspiron 15-7547 RAM Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-7547 RAM Replacement: passo 5, imagem 2 %32
    • Pull the RAM stick in a straight line out of the socket.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 307
