Ir para o conteúdo principal
Dell Inspiron 15-7547 Motherboard Replacement
O que você precisa
  1. Dell Inspiron 15-7547 Motherboard Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Motherboard Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Motherboard Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Motherboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 4, imagem 2 %32
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Motherboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 5, imagem 3 %32
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
  6. Dell Inspiron 15-7547 Motherboard Replacement, WiFi Card: passo 6, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, WiFi Card: passo 6, imagem 2 %32
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  7. Dell Inspiron 15-7547 Motherboard Replacement: passo 7, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  8. Dell Inspiron 15-7547 Motherboard Replacement: passo 8, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  9. Dell Inspiron 15-7547 Motherboard Replacement, Hard Drive: passo 9, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, Hard Drive: passo 9, imagem 2 %32
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  10. Dell Inspiron 15-7547 Motherboard Replacement: passo 10, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 10, imagem 2 %32
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  11. Dell Inspiron 15-7547 Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the hard drive out of the chassis.
  12. Dell Inspiron 15-7547 Motherboard Replacement, CPU Fan: passo 12, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, CPU Fan: passo 12, imagem 2 %32
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  13. Dell Inspiron 15-7547 Motherboard Replacement: passo 13, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 13, imagem 2 %32
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  14. Dell Inspiron 15-7547 Motherboard Replacement: passo 14, imagem 1 %32
    • Lift the fan out of the chassis.
  15. Dell Inspiron 15-7547 Motherboard Replacement, RAM: passo 15, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, RAM: passo 15, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement, RAM: passo 15, imagem 3 %32
    • Remove the plastic heat spreader that covers the RAM sticks.
  16. Dell Inspiron 15-7547 Motherboard Replacement: passo 16, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 16, imagem 2 %32
    • Release the clamps on each side of the RAM sticks by pushing away from the center.
    • When done properly the RAM stick should pop up.
  17. Dell Inspiron 15-7547 Motherboard Replacement: passo 17, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 17, imagem 2 %32
    • Pull the RAM stick in a straight line out of the socket.
  18. Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: passo 18, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: passo 18, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement, LCD Assembly: passo 18, imagem 3 %32
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  19. Dell Inspiron 15-7547 Motherboard Replacement: passo 19, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 19, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 19, imagem 3 %32
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  20. Dell Inspiron 15-7547 Motherboard Replacement: passo 20, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 20, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 20, imagem 3 %32
    • Raise the left and right hinges.
  21. Dell Inspiron 15-7547 Motherboard Replacement: passo 21, imagem 1 %32
    • Remove the LCD display assembly from the laptop.
  22. Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: passo 22, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: passo 22, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement, Motherboard: passo 22, imagem 3 %32
    • Unlatch the ribbon cable by pulling the white release up.
    • If this proves to be difficult using your fingers, try a plastic spudger.
    • Hold the blue flap and pull to unplug the cable.
  23. Dell Inspiron 15-7547 Motherboard Replacement: passo 23, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 23, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 23, imagem 3 %32
    • Unlatch black release on the ribbon cable.
    • Hold the blue flap to unplug the cable.
  24. Dell Inspiron 15-7547 Motherboard Replacement: passo 24, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 24, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 24, imagem 3 %32
    • Unlatch the ribbon cable by pulling the black release up.
    • Unlike the others, this release is found at the back.
    • Hold the flap and unplug the cable.
  25. Dell Inspiron 15-7547 Motherboard Replacement: passo 25, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 25, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 25, imagem 3 %32
    • Unlike the others this release is found at back.
    • Hold the blue flap and unplug the cable.
  26. Dell Inspiron 15-7547 Motherboard Replacement: passo 26, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 26, imagem 2 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 26, imagem 3 %32
    • Unplug the DC jack cable.
  27. Dell Inspiron 15-7547 Motherboard Replacement: passo 27, imagem 1 %32 Dell Inspiron 15-7547 Motherboard Replacement: passo 27, imagem 2 %32
    • Remove the seven 3.0 mm-long Philips #0 screws that secure the motherboard.
  28. Dell Inspiron 15-7547 Motherboard Replacement: passo 28, imagem 1 %32
    • Remove the motherboard from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 727
