Ir para o conteúdo principal
Dell Inspiron 15-7547 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-7547 Hard Drive Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 15-7547 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Remove the four 5.0 mm-long Philips #0 screws connecting the hard drive to the chassis.
  4. Dell Inspiron 15-7547 Hard Drive Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7547 Hard Drive Replacement: passo 4, imagem 2 %32
    • Disconnect the hard drive from the motherboard by placing your fingers at the back, and pulling forward towards the front of the chassis.
  5. Dell Inspiron 15-7547 Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift the hard drive out of the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 701
