Ir para o conteúdo principal
Dell Inspiron 15-7547 CPU Fan Replacement
O que você precisa
  1. Dell Inspiron 15-7547 CPU Fan Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 CPU Fan Replacement: passo 2, imagem 1 %32
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: passo 3, imagem 1 %32 Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: passo 3, imagem 2 %32
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Dell Inspiron 15-7547 CPU Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-7547 CPU Fan Replacement: passo 4, imagem 2 %32
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Dell Inspiron 15-7547 CPU Fan Replacement: passo 5, imagem 1 %32
    • Lift the fan out of the chassis.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 554
