Introdução
Use this guide to replace the RAM if you would like to upgrade the RAM, or replace it if there is damage.
O que você precisa
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Gently pull apart clips on the ends of the memory module until the memory module pops up.
