Ir para o conteúdo principal
Dell Inspiron 15-7537 Battery Replacement
O que você precisa
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: passo 1, imagem 1 %32
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: passo 3, imagem 1 %32
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: passo 5, imagem 1 %32
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
Conclusão
4 outras pessoas executaram este guia.
Abby Schmiedt
Membro desde: 01/22/15
229 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-2, Maness Winter 2015 Membro de Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 7,027
