Introdução
The battery is needed to power the laptop. A bad battery must be replaced, which can be done with this guide.
O que você precisa
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
4 outras pessoas executaram este guia.
