Ir para o conteúdo principal
Dell Inspiron 15-5567 I/O Board/Cable Replacement
O que você precisa
  1. Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: passo 1, imagem 1 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: passo 1, imagem 2 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement, Back Cover: passo 1, imagem 3 %32
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 2, imagem 2 %32
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 3, imagem 2 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 3, imagem 3 %32
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: passo 4, imagem 1 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: passo 4, imagem 2 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement, I/O Board/Cable: passo 4, imagem 3 %32
    • Open the latch for the cable using the blue opening tool by placing it under the latch (like in the second picture) and lifting it upward.
    • Disconnect the cable by pulling the blue tab.
  5. Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-5567 I/O Board/Cable Replacement: passo 5, imagem 3 %32
    • Remove one M2.5x5mm screw securing the board using a Philips #0.
    • Lift the board gently and remove it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 703
