Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ferramentas
Peças
Não são necessárias peças.
Lift the latch and using the pull tab, disconnect the hard-drive cable from the system board.
Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
Connect the hard-drive cable to the system board and close the latch to secure the cable.
