Ir para o conteúdo principal
Dell Inspiron 15-5567 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Display Cable: passo 1, imagem 1 %32
    Step one incorrectly identifies the display cable as the battery cable. I think I blew the mobo reattaching the display cable. A small pop and some ozone scent leads me to believe that.
    Quietech - Responder
  2. Dell Inspiron 15-5567 Display Assembly Replacement, Note the Display Cable Routing: passo 2, imagem 1 %32
    • Note the display cable routing and remove the cable from its routing guides.
  3. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: passo 3, imagem 1 %32 Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Latch: passo 3, imagem 2 %32
    • Lift the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 15-5567 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the display hinges to the palm rest and keyboard assembly.
  5. Dell Inspiron 15-5567 Display Assembly Replacement, Open the Display Hinges: passo 5, imagem 1 %32
    • Open the display hinges.
  6. Dell Inspiron 15-5567 Display Assembly Replacement, Lifting the Palm Rest: passo 6, imagem 1 %32
    • Lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 15-5567 Display Assembly Replacement, Placing the Display Assembly: passo 7, imagem 1 %32
    • Place the palm rest and keyboard assembly on the NEW display assembly.
  8. Dell Inspiron 15-5567 Display Assembly Replacement, Press the Display Hinges: passo 8, imagem 1 %32
    • Using the alignment posts, press the display hinges down on the palm rest and keyboard assembly.
  9. Dell Inspiron 15-5567 Display Assembly Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the display hinges to the palm rest and keyboard assembly.
  10. Dell Inspiron 15-5567 Display Assembly Replacement, Routing the Display Cable: passo 10, imagem 1 %32
    • Route the display cable through the routing guides on the palm rest and keyboard.
  11. Dell Inspiron 15-5567 Display Assembly Replacement, Sliding the Display Cable: passo 11, imagem 1 %32
    • Slide the display cable to the connector on the system board and close the latch to secure the cable.
    • Slide the battery cable to the connector on the system board.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
Um comentário
Nice, is the part available?
gideon onwuka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 2,053
