Introdução
Laptops can start giving you trouble if the battery life shortens and the laptop starts losing its charging more quickly. This guide is an easy way to replace the battery for a Dell Inspiron 15-5567 laptop. When working with laptops it is important to make sure that there is no current running through the laptop and that is completely shut down before being opened up. The interior of a laptop is very delicate and therefore must be handled with great care to make sure nothing gets scratched inside that might impact the function of the laptop.
O que você precisa
Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
5 outras pessoas executaram este guia.
Um comentário
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
