Ir para o conteúdo principal
Dell Inspiron 15-5567 Battery Replacement
O que você precisa
  1. Dell Inspiron 15-5567 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off the laptop and wait 20 minutes before beginning disassembly.
    • Use a Phillips #0 screwdriver to remove 15 screws from the bottom of the laptop.
  2. Dell Inspiron 15-5567 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5567 Battery Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-5567 Battery Replacement: passo 2, imagem 3 %32
    • Slide the DVD drive out of the laptop.
    • Remove the three screws underneath using a micro screwdriver.
    • Pry off the back cover of the laptop using an opening tool.
  3. Dell Inspiron 15-5567 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5567 Battery Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two screws attached to the metal bracket holding down the battery.
    • Remove the screw attached to the laptop battery using a Phillips #0 screwdriver.
  4. Dell Inspiron 15-5567 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5567 Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the battery connecting cable from the laptop by sliding it out.
    • Confirm the new battery is correct for this laptop model by looking at the battery type and power.
  5. Dell Inspiron 15-5567 Battery Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5567 Battery Replacement: passo 5, imagem 2 %32
    • Attach the cable for the new battery to the laptop by sliding the cable into the port.
Conclusão
5 outras pessoas executaram este guia.
Saaed Chaudhry
Membro desde: 07/15/20
382 Reputação
Autoria de 2 guias
Um comentário
This battery did not come with the new cable. I had to reuse the old cable, which was very difficult to do.
Kat Vinson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 63
Duração total: 7,616
