Introdução
Before you begin, make sure that your device is disconnected from any power sources and be sure that the battery has been removed. You'll need a Phillips #1 screwdriver and a black nylon spudger to complete this guide.
O que você precisa
Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
4 outras pessoas executaram este guia.
2 comentários
The blue part came off is that important?
can i put this in a harddrive enclosure?
