Ir para o conteúdo principal
Dell Inspiron 15-5559 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32 Dell Inspiron 15-5559 Hard Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
  2. Dell Inspiron 15-5559 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5559 Hard Drive Replacement: passo 2, imagem 2 %32
    • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
    • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
  3. Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Dell Inspiron 15-5559 Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove each of the four (4) 2.5x8mm screws that anchor the hard drive using a Phillips #1 screwdriver.
  4. Dell Inspiron 15-5559 Hard Drive Replacement: passo 4, imagem 1 %32
    • Use the plastic spudger to remove the hard drive conductive tape by lifting the black clasp holding it down, then pulling the conductive tape toward the left to remove it.
    • It does not take much force to remove the conductive tape. Remove it gently so that you do not damage it.
  5. Dell Inspiron 15-5559 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5559 Hard Drive Replacement: passo 5, imagem 2 %32
    • Place the plastic spudger underneath the hard drive at the indicated position.
    • Use the spudger along with your other hand to gently remove the hard drive.
Conclusão
4 outras pessoas executaram este guia.
Kyla Ward
Membro desde: 03/19/18
580 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S5-G5, Williams Spring 2018 Membro de Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
Membros da 3
Autoria de 5 guias
2 comentários
The blue part came off is that important?
walterandradeconde - Responder
can i put this in a harddrive enclosure?
chiggly 123 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 42
Duração total: 5,241
