Ir para o conteúdo principal
Dell Inspiron 15-5558 Screen Replacement
O que você precisa
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: passo 2, imagem 1 %32
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Screen Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5558 Screen Replacement: passo 3, imagem 2 %32
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: passo 4, imagem 1 %32 Dell Inspiron 15-5558 Screen Replacement, Screen: passo 4, imagem 2 %32
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
  5. Dell Inspiron 15-5558 Screen Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5558 Screen Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-5558 Screen Replacement: passo 5, imagem 3 %32
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: passo 6, imagem 1 %32 Dell Inspiron 15-5558 Screen Replacement: passo 6, imagem 2 %32 Dell Inspiron 15-5558 Screen Replacement: passo 6, imagem 3 %32
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
Conclusão
6 outras pessoas executaram este guia.
Adam Lourenco
Membro desde: 10/19/17
775 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
Membros da 3
Autoria de 5 guias
2 comentários
Where can I buy the screen from?
wardak_90 - Responder
How many pins is the screen connector? 30? 40?
Adrian Lewis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 4,662
