Introdução
If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
O que você precisa
Open device so it is at least opened at a 90 degree angle.
Wedge a spudger between the screen and the plastic frame.
Push in the spudger and push down to pop the frame from the pins.
Repeat around the whole frame.
6 outras pessoas executaram este guia.
2 comentários
How many pins is the screen connector? 30? 40?
