Ir para o conteúdo principal
Dell Inspiron 15-5558 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15-5558 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5558 Keyboard Replacement: passo 3, imagem 2 %32
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Inspiron 15-5558 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Identify the two small slots along the side of the keyboard closest to the screen.
    • Wedge the spudger in the two small slots and push the spudger in and down to detach the pins.
    • Using your hands, pull the keyboard up and out.
  5. Dell Inspiron 15-5558 Keyboard Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5558 Keyboard Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-5558 Keyboard Replacement: passo 5, imagem 3 %32
    • At the end of the ribbon cable attaching the keyboard to the device is a bar secure.
    • Using your finger or spudger, flip the bar up and the keyboard will be freed from the device.
Conclusão
5 outras pessoas executaram este guia.
Adam Lourenco
Membro desde: 10/19/17
775 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 1,861
