Ir para o conteúdo principal
Dell Inspiron 15-5558 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 15-5558 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Inspiron 15-5558 Hard Drive Replacement: passo 3, imagem 2 %32
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Dell Inspiron 15-5558 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
    • Take a spudger and wedge it between the panel and the base of the device.
    • Push down on the spudger until you hear a click sound.
    • Slide the spudger along the panel and continue to push down until the panel is completely detached.
    • Remove the panel.
  5. Dell Inspiron 15-5558 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Inspiron 15-5558 Hard Drive Replacement: passo 5, imagem 2 %32 Dell Inspiron 15-5558 Hard Drive Replacement: passo 5, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
    • Take the spudger and prop up the connector so it is no longer attached.
    • Use the spudger and prop up the hard drive and remove it.
Conclusão
4 outras pessoas executaram este guia.
Adam Lourenco
Membro desde: 10/19/17
775 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G4, Bailey Fall 2017
UMASSD-BAILEY-F17S3G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Duração total: 4,661
