Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Make sure the laptop is powered down before you remove the battery.
Locate the battery release switch on the bottom of the laptop.
Slide the battery release switch away from the lock symbol towards the “unlock” position.
Rotate the battery outward by lifting the bottom lip that pops out.
Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Flip the device on its back, locate the screws circled.
Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Remove the dislodged up RAM by pulling it away from the connection.
