Ir para o conteúdo principal
Dell Inspiron 15-5552 Memory Replacement
O que você precisa
  1. Dell Inspiron 15-5552 Memory Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Memory Replacement: passo 2, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Memory Replacement: passo 3, imagem 1 %32
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Memory Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5552 Memory Replacement: passo 4, imagem 2 %32
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Memory Replacement, Screw Location: passo 5, imagem 1 %32
    • Flip the device on its back, locate the screws circled.
  6. Dell Inspiron 15-5552 Memory Replacement, Screw Removal: passo 6, imagem 1 %32
    • Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
  7. Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, imagem 1 %32 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, imagem 2 %32 Dell Inspiron 15-5552 Memory Replacement, Removing Cover: passo 7, imagem 3 %32
    • Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
  8. Dell Inspiron 15-5552 Memory Replacement, RAM Removal: passo 8, imagem 1 %32 Dell Inspiron 15-5552 Memory Replacement, RAM Removal: passo 8, imagem 2 %32
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  9. Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: passo 9, imagem 1 %32 Dell Inspiron 15-5552 Memory Replacement, RAM Removal Contiuned: passo 9, imagem 2 %32
    • Remove the dislodged up RAM by pulling it away from the connection.
    • If it does not pop up, pry it out in a steady and straight direction.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 329
