Ir para o conteúdo principal
Dell Inspiron 15-5552 Battery Replacement
O que você precisa
  1. Dell Inspiron 15-5552 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Battery Replacement: passo 2, imagem 1 %32
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Battery Replacement: passo 3, imagem 1 %32
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 15-5552 Battery Replacement: passo 4, imagem 2 %32
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 254
