Ir para o conteúdo principal
Dell Inspiron 15-5548 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Dell Inspiron 15-5548 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Open up the front of the laptop.
    • Locate the 5 holes at the top of the keyboard, as circled in Picture 2.
    • Use the metal spudger to pry up the keyboard at each of the 5 points.
    • This may take some extra force, and it should pop when it is pried off.
  2. Dell Inspiron 15-5548 Keyboard Replacement: passo 2, imagem 1 %32 Dell Inspiron 15-5548 Keyboard Replacement: passo 2, imagem 2 %32 Dell Inspiron 15-5548 Keyboard Replacement: passo 2, imagem 3 %32
    • When all the points have been pried up, gently lift the keyboard.
    • Lift the ZIF tabs holding down the two ribbon cables, and gently remove them.
    • Remove the keyboard.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 1,616
